Complete Tremec TKO and 5spd Conversion
Old Oct 28, 2007 | 10:23 PM
IROCFAST's Avatar
I have a complete 5spd conversion for a 3rd gen. Everything from the pedals to the tremec output shaft. This is as complete as it gets. Comes with newer ram clutch, and slave cyl. All parts are in good condition and were not used that long. Switching to an auto. Prefer not to ship but will at buyers expense.
$1500 obo
Old Oct 29, 2007 | 09:09 AM
drdan1341's Avatar
Car: 83 Trans Am
Engine: Procharged 406
Transmission: 5 speed
Re: Complete Tremec TKO and 5spd Conversion
what is the part # on it, thanks, dan.
Old Oct 29, 2007 | 02:26 PM
IROCFAST's Avatar
I do not know off the top of my head, I will check that tonight and get back with you.
Thanks,
Brit
Old Oct 29, 2007 | 11:09 PM
rhit_rs's Avatar
Did you have any problems whatsoever with the transmission, or the whole set-up? What bellhousing does it come with? Will the stock driveshaft work? Will the stock torque arm bolt up as well?
Old Oct 29, 2007 | 11:41 PM
IROCFAST's Avatar
I used it for a little while and it worked great. It uses the stock bellhousing with an adapter. Yes you can use your stock ds, this one comes with a yoke to adapt it. And it has provisions to use your stock torque arm.
Old Oct 30, 2007 | 10:32 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
how much if you ship to: TN 37167-4506?
Old Oct 30, 2007 | 11:53 AM
Dels383TA's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: Ford 9"(Moser),4:11s,locker,31splin
Is this a TKO 500 or a TKO 600,also are you will to ship to Canada?What does it have for a shifter(brand,short)?
Thanks DEL
Old Oct 30, 2007 | 02:09 PM
IROCFAST's Avatar
It is the TKO before the 500 & 600 were out. It has the stock shifter.
Old Oct 30, 2007 | 02:21 PM
IROCFAST's Avatar
Shipping would be about $175
Old Oct 30, 2007 | 02:30 PM
rhit_rs's Avatar
What are it's torque handling capabilities? How old is the transmission itself? What are the gear ratios?
Old Oct 30, 2007 | 05:20 PM
IROCFAST's Avatar
http://www.ttcautomotive.com/English...ts/TR-3550.asp
This link will provide you with all the specs. It is the standard TKO w/ the .68 fifth gear ratio. There are guys in the 10's on this exact trans and a few mustang guys in the nines with the ford version. The trans itself was bought in late 2003 early 2004 when I still lived in Southern IL.
Old Nov 3, 2007 | 01:31 AM
DREGSZ's Avatar
TKO 3550
Has AL shift forks, awsome tranny but don't miss any shifts. only takes once to learn that...
I put 600 hp 550 tq to mine for 3 years of road course racing
Old Nov 3, 2007 | 11:03 AM
IROCFAST's Avatar
SOLD
RyanJB
May 7, 2016 06:23 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
LittleFranks
Oct 7, 2015 11:26 PM
MORREALE5
Sep 13, 2015 09:01 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
