[CO] 85-92 tpi iac upgrade
Old Jan 9, 2019 | 12:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jan 9, 2019 | 12:48 PM
Engine: Lb9
Transmission: M20
Re: 85-92 tpi iac upgrade
85-92 tpi iac upgrade $125 shipped
all new parts
lt1 iac and ramjet 502 lower iac plate.
tight clearance between the lower plate and thermostat housing.
some filing maybe required.
unknown if this works with aftermarket intake manifolds and runners.
harness screws and gasket included.
to bypass the coolant hose use Dayco 87662
Old Jan 10, 2019 | 08:08 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Is there a tread anywhere to read and understand the benefits
Old Jan 10, 2019 | 08:30 PM
Engine: Lb9
Transmission: M20
Not that I know of, cleaner bypass look and cheaper iac replacement cost.
Ronny
Oct 29, 2008 01:30 PM
Slow89Iroc-Z
Sep 18, 2003 03:50 PM
