IAC stay alive vs actual iac position
Old Sep 17, 2003 | 09:45 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
What are they and what should they be at? My actual IAC position at idle is 0 and the iac min keep alive position is 11? I am trying to get rid of an idle stumble. See it idles fine around 800rpm for about 20sec and then stumbles and the car shakes then idles fine. During the stumble I also get knock retard.....Just idleing I get 100's of counts but if I drive I get maybe 20 or so more.....Car mods in sig....
Old Sep 18, 2003 | 06:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: IAC stay alive vs actual iac position
No sig. If still running an '89 code mask/ECM the value at location $1B9 is the RPM threshold to allow knock retard as: Val = RPM / 12.5
Set it to 1000 RPM or so.
RBob.
Old Sep 18, 2003 | 01:21 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I am running the 730 SD now...
Old Sep 18, 2003 | 01:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Scroll down a tad for the subject: idle knock (7730)
RBob.
Old Sep 18, 2003 | 02:45 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I have a hex editor and the bin loaded....but where is 820a? My bin file stops at 8000?
Old Sep 18, 2003 | 03:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Drop the $8000 part off. Location $820a is the address once the EPROM is placed into the ECM. In the EPROM the address is $20A.
IE: the EPROM is offset by $8000 by the address decode of the ECM.
RBob.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
