WTS parts ALL still new in boxes
1.TCI Trans cooler kit 6an setup.$35
2.TCI flex Plate SFI sert 168 tooth Inturn Bal $50
3.Canton Racing oil pan kit #13.100 with
Melling HV oil pump w/pick up for above pan w/ canton1 piece pan gasket
temp bungs dip stick bung..turbo/blower drain back.ARP pump stud $275
4.billet PVC breathers x2 $40
5.ATI Super Damper $275
6.ATI Billet timing pointer for above Damper. $30 ….(or both for $300)
7.AFR 220 race ready heads #1112 $1500
8.APR SBC Head bolt SS outer bolts in this set $100
9.felpro blue 1 pieces oil pan gasket $30
10.GM PP mini starter as new per mag type $120 (was used for a month) you could put this in your pocket its so light!
11.MSD Mini starter $190
12.canton racing over flow $110
13.canton racing billet oil filter kit..takes cantons filters $130
14. RCI 1 gal fuel cell aluminum $110
15.Pete Jackson Quiet Gear drives yes Pete jackson (new in boxes even) $120 have 3.. (I ran this type in my 92 camaro with efi)
16. 427 all forged H beam rod SLP piston aftermarket block (short block) $2100
cometic MLS head gaskets for above block. Buy block and heads ill give you gaskets. pushrods..and and make a sweet deal on all the other parts.. timing covers. pete jackon gear drives.. timing chains..alot of parts for the SBC..
ALOT OF OTHER PARTS will take some pics today all parts are brand new in boxes
could make a deal.. and put on a pallet wraped up ALL the above parts.. cheap..need the room.. Don't need small block parts any more..
shipping is not included in the prices..but I will make deals on the more you buy..
articwhiteZ
09-25-2018 07:21 PM
articwhiteZ
02-04-2010 06:17 PM
smallblock383
11-27-2007 08:39 AM
smallblock383
11-18-2007 04:43 PM
