[Sold] Vortec Stealth Ram + EBL Flash + TPI Airbox
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Hey guys,
I've decided to go a different direction with the car, so my whole Stealth ram setup is for sale. For enough money I'll include the heads!
Asking $1000, will part out if there's enough interest. I have everything you need except the harness, those are just too vehicle specific, but it's actually not too difficult to splice one together, I hate wiring and I thought it was pretty simple. If you have any questions about that I'm happy to help!
This EBL Flash is a TBI ecm, but it can run all the same tunes as the TPI ecm. If you want to upgrade your TBI to port injection, all you need is the pigtails for the injectors. I can snip off that section of my harness for you, or you can make one yourself. This is probably ideal for someone with a TBI car wanting to upgrade, but if you get a TBI harness cheap all you'll need to do is splice it into your bulkhead connector on the driver's side of the firewall.
I can get closer pictures if you want, but this is the setup:
Included:
-EBL Flash w/ Port mod and disc for your laptop, plus USB adapter (I've had zero problems with the USB adapter, works great)
-Vortec Stealth Ram
-Holley Vortec fuel rail
-Kirban 6547 adjustable fuel pressure regulator
-30 lb/hr Bosch D3 Fuel Injectors, new from Southbay Fuel Injectors Dec 2018
-smallcap HEI distributor + Delphi ignition coil + spare coil + spare distributor (I had lots of ignition problems prior to EFI and the dist in the car was used, so I actually have a brand new in box spare to go with it, one of the things Im happy to sell separately if there's interest)
-LT1 throttle body with no coolant connections, so have the automatic coolant bypass mod on this. The sensors in it are new and it works fine, but since the coolant nipples are broken off, this is kind of a throw in. It'll work fine. I have the correct adapter harness to run TPI plugs into it. One of the sensors ( the TPS maybe?) Has a different plug than the thirdgen throttle bodies.
-Also have seperate Multec LT1 injectors somewhere, worked fine, 24 lb/hr allegedly, and that's how I set it up. The video is with these LT1 injectors.
In the first video, it is shown with a firebird L-snorkel on it. If you want that, I'll include it with the filter and so on if you buy the whole kit. Not really sure which model it came out of, but it fits the HSR perfectly. If youre wanting to put it in a TA/Bird it's perfect.
Additionally, I have a full TPI Air Box, I couldnt use it with my 82 Z28 hood, so I grudgingly set it off to the side. This has the SPEED DENSITY V8 snorkel with it, so it doesnt have the restrictive MAF area in it. A little tough to find. $175 if you come get it for the whole kit. Shipping for something this awkwardly large will be tricky to keep cheap, but I'll work with you on it for sure if you want it.
Let me know if there's any interest in the whole thing or individual parts.
$1000 for the full HSR and EBL + (if you want it) firebird snorkel
$1150 for HSR + EBL + TPI Airbox/snorkel Assembly
$175 for TPI airbox with Speed Density snorkel
Included:
-Vortec Stealth Ram
Spaceboy1980
Alternative Port EFI Intakes
30
Dec 4, 2014 02:34 AM
