Complete FIRST tpi unit
Old Mar 19, 2020 | 07:05 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
Base, runners, plenum, throttle body, fuel rails, injectors. PLUS computer controlled distributor PLUS EBL P4 Flash, harness, Plus book of real word tuning notes, bins etc. $1400 takes it all.
Old Mar 20, 2020 | 09:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Complete FIRST tpi unit
I recall when they were the hot set up, and bless you for keeping that '69 carb'ed
Old Mar 20, 2020 | 10:45 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Thanks.
Old Mar 21, 2020 | 09:50 AM
Gary Anderson's Avatar
Traditional or Vortec port?
Old Mar 21, 2020 | 03:24 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Traditional
Old Jun 4, 2020 | 09:14 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
This First is up for sale. I just don’t want to go thru all the work to convert to EFI. Some additional info. Injectors are 42 lbs. MAP sensor and bracket also included. This is a complete system
Distributor, harness. EBL Flash P4
Satin finish on plenum. Runners powder coated in Matte River Black. Manifold natural glass beaded aluminum. Rails and injectors not shown
Old Jun 15, 2020 | 11:12 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Do you know what engine the base is for? What angle are the center bolt holes on the base? 72 degree for the later model stuff or 90 degree? I assume it's the 90 degree since it was going to be for a 69 but I don't know if this is one of the intake bases that accepts both.
EDIT: Just noticed that I posted on the wrong thread, well not really wrong since it's the same seller, but I had intended to continue the conversation from https://www.thirdgen.org/forums/engi...-tpi-sale.html. Whoops. Feel free to reply to whichever.
Old Jun 16, 2020 | 06:41 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
It is for the standard small block.
Old Jun 16, 2020 | 06:38 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Bump
Old Jun 17, 2020 | 08:15 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
Originally Posted by ToolGuru
Bump
I know you probably aren't interested in splitting it up, but if someone wants to buy all of the efi extras I'd be happy with just the intake. I'm running fast xfi, 72lb injectors with a miniram but for some reason I want this intake.
If that occurs please let me know.
Old Jun 17, 2020 | 10:17 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Interested. What size are the ports?
Old Jun 18, 2020 | 08:01 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
1204. Injectors were just clean and flowed. Holley 42 lbs.
Old Jun 18, 2020 | 01:03 PM
Looks like I'll be staying with the 083 heads I have so it won't work for me. This is a deal for whoever gets it. Good luck with the sale.
Old Jun 18, 2020 | 02:29 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
What are the port sizes on those heads? It certainly isn’t hard to gasket match the ports?
Old Jun 18, 2020 | 02:38 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
I’m just guessing at the gasket size. The ports on the intake measure about 1.150 across and 1.937 across
Old Jun 18, 2020 | 02:41 PM
Not a port size issue. It's a head bolt issue. Since that is the standard pattern for the inboard 2 bolts then it won't work on my 083 heads and I'd prefer to not grind out those 4 holes. I had a line on a set of 113 heads that would have matched the First, but abruptly I no longer have those available to me, so I'm sticking to my 083s.
Old Jun 18, 2020 | 03:13 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
The previous owner has already ovaled the holes out and you can get wedged spacers for the holes to take up the gap. Also, you can send the manifold back to FIRST and they’ll drill them out for you. It’s part of hotrodding, man!
Old Jun 18, 2020 | 03:22 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Spike_Akers
May 6, 2013 02:10 PM
TAZ
Jul 23, 2003 05:29 PM
