selling some BMR suspension parts that have been sitting around for a while after i pulled them off my car. Was going to reuse on a new build, but changing it up a bit.
BMR Kmember. KM007R. SBC/bbc type engine mounts. Had steering rack bolts added on but can be cut off for stock steering setup. Needs a good blasting/cleaning and paint. $350
BMR A arms. AA007R. No spring mounts, for use with coil overs. Would replace the ball joints before using these.
$220
BMR track pak torque arm kit. TPU001R. Only thing missing is the small metal brackets for welding the tube ends.
$250
BMR SP008R coil over kit. Comes with stock 200lb springs as well as a set of brand new 150lb eibach springs. Missing spanner wrench.
$650
good drag racing setup. Located near savannah Georgia.
