[VA] 330 ci tpi, whole or parts
Old Mar 11, 2021 | 07:57 PM
Ziggy757's Avatar
Want a title? Post!
I have a 327 bored 60 over, zero deck.
Rods stock with ARP bolts resized
steel small journal crank balanced assembly
KB hyper pistons flat top, motor should be just about 11 to 1
Heads are TPIS AFR, 2200$ new ,titanium retainers, flow a was 286 in
Cam is a tpis custom grind , 600 lift about 300 duration roughy 250 at 50, slightly larger than a zzx but close
Intake is Edelbrock base, Edlebrock runners, 52mm Tb 24lb injectors
Motor has about 3000 miles, runs incredible. I also have a 3000 stall vigilante converter I will sell separately
Motor complete with the intake , harness which was purchased new, computer and Moates programming hardware is $5600
Im willing to sell off the short block, cam and lifters, rockers and heads and will sell the intake whole with the computer and harness plus all sensors including the gutted MAF
Intake complete with the harness, computer and moates stuff as well as dist. $2300 note: I will be having the runners re powdercoated as they did not fully harden and the Powder coated owes me this. $2300
Heads without covers $1200
Short block without cam and lifters $1600
Comp cams 1.5 steel roller rockers $260
Cam with solid roller lifters 500$
700r4 vig convertor $500
VinnyX40
May 24, 2015 10:13 AM
formula
Aug 5, 2011 10:10 PM
dj
Sep 18, 2006 05:12 AM
Blkdth87
May 10, 2004 04:05 PM
