[NC] Accessory bolt info...help needed!!
I took the motor apart in my 1985 Iroc almost 8 years ago, and I am finally putting a new motor in now. Over the years I have apparently lost all my accessory bolts. Looking for help on what bolts I need to buy, or anywhere I can get a full kit. The car is an 85 Iroc, originally a 305 TPI car, now a 350 with a HSR.
Thanks in advance for the help.
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Re: Accessory bolt info...help needed!!
You will likely have better luck getting info over at the TPI board.
Car: 1987 GMC 1500 4x4
Engine: 383 roller, MPFI ecu by FAST
Axle/Gears: 3.73 Eaton Trutrac 30 spline convsn
i believe the bolts that go into the cylinder heads are 3/8"
Chris_89rs
Jun 10, 2012 11:03 PM
