WTS med cap/ billet/accel/stuff. SBC stuff..whatnot.
Cleaning out alot of stuff not going to use... all parts/stuff brand new! just mock up if out of box at all..
have a box of 10 accel spark shorty spark plugs (large box) $40 will also toss in 4+ plugs from the Dyno still like new.SOLD
Accel DFI Fuel filter and ss lines & fitting (blue) will post photos $60 (AN fitting are more then this with #6AN line and TPI Filter..)NIB
MSD cap rotor for the Remote coil set up TPI $25 dont remember what they sell for..SOLD
Aluminum 2 piece timing cover SBC New in box will toss in gasket set (what ever I have ) $70 felpro.
NOS cheater plate used $55. SOLD
Canton Racing billet oil filter. takes Canton racing filters.. $80.
Chrome Power steering Pump. New In Box bolt on pully type SOLD
Billet 1350 9" yoke new $80 will be 2 yokes both new 1 forged 1 billet both 1350 u joints
silicone sbc valve cover gaskets (still sealed in black Bags buy anything above add $10 there yours
hood struts glass hood or steel you pick ill toss them in..(new in bags/pack)
replacement pullys for the TPI cars AC delete. Air pump Delete new in box Ill toss them in..
ZeXs NOS Plates have 2 new in box $55 ea or $100 for both..
Fuel logs by moroso (used)
fuel logs Fuel lab new in box .. just a lot of parts would like to move out ..
$300 takes it all and some not even listed.. will toss in add $15 shipping for the lot.. will toss in fuel pressure gauge (new in box) so much SBC stuff
JUST Ask..have alot of stuff would like to just box it up.. and send it to somebody that could use it...
solid trans Mount 700R4 th400
TPI replacment pullys new in box ..also have AC & Smog Delete Brackets to go with the new pullys
Moroso Fuel log/presh reg all in 1 $50
TCI Out law shifter plates 1 forward pattern & 1 revers pattarn both for $30
GM chrome power steering Pump bolt on pully style..new in box. $75
fiber glass and steel hood struts
Canton Racing Billet filter housing. (blue) SBC/BBC. New in box takes there filters.$70
Polished 2 Piece timing cover SBC with felpro gasket set. cover/water pump/crank seal. new in box!
10 spark plugs new in box..will also toss in 4+ or more from dyno..as new..
RCI 5 Point out of date..by a few years..but still new in box.. also have a used set will toss in with this set for 2 full sets..$50 for 2 sets
MSD Cap And Rotor new! no box..will go with a TPS. ICV AND MAP new in box
Re: WTS med cap/ billet/accel/stuff. SBC stuff..whatnot.
Originally Posted by Gibby10
pictures?
ill post some Monday
MDS cap and rotor new no box for the Remote coil cars/TPI and tossing in a IAC with MAP and TPS 2 parts are in 1 box..parts are new in box TPS was Mock up only..
1350 U joint billet yoke New.and moog bolts/straps new.. will toss a Fast shafts 1350 forged yoke. they make light wt.both 9" Ford. good stuff.
fuel press gauge
gotcha. I'm guessing the Zex plates are purple, which is not a color found anywhere on my car... so i would probably take a pass on those. I won't even be installing the nitrous parts until September of this year, but if any of the plates seem to fit the look/use I am going for, I might jump on a deal. Needs to be able to flow a 200 wet shot on a standard 4150 style setup (sandwiched between a holley sniper throttle body and edelbrock victor Jr intake manifold. No rush at all, simply just curious.
there is a good change I might buy ONE of the plates you have for sale. If you are able to take a photo(s) of all of em, and if you have advice on which one would be best for a 150-200 shot, that would be awesome.
Originally Posted by 2slow5.0
Do you have a serpentine pulley to work with the pump?
march makes one. wish I had better pics..but this pully was on the pump. (bolt on) for mock up..
in this pic you can see the pump that is for sale. with the same march pully now mounted on the Big Block..above
You Know what's sad...Ordering a part..Getting A part...finding you already have the part..when you go to put the part away...(have done this 2 times now)
On the Other hand.. sorting parts out to use.. and finding parts you forgot about..Having...it's like Xmas !!
Nos Plates pic
NOS cheater plate used $55 shipped
ProComp Plates have 2 New In Boxes open box to take pic $60 ea or $100 for the 2 plates/set (full on copy of the Zex Plates) but in black.
cool, thanks. I did a bit of research an even though those perimeter style nitrous plates seem cooler, most people are of the opinion that the traditional spray-bar style plate performs better. I know you have not used the perimeter plates, but do ya have any thoughts on this topic? I'll be spraying a 150-200- and mayyyybe a 250 progressive shot one day, but lets call it a 150 shot for now. Therefore I am leaning more towards the NOS cheater spray-bar style plate. Seems like it would just need a coat of paint, two gaskets, and some jets ? I plan to make my own feed lines, and solenoid mounts, but the plate would need to be mounted for me to start all that anyways. Thoughts? I can PM you if you want to figure out payment. Thanks
I picked up the ProForm Plates to use.. But found I could not install A 90 deg fitting into the plate. they want you to use bent tubing..I have always used foggers Set ups. and have ran NOS for over 30+ years..from 1983.. anyway..I wanted to set My intake up in a way for function and looks.. Braded SS 4an to 3 an in the plates.shown below. all tubing is braded SS. with AN fittings. so I could not use the Proform Plates..I have played with the perimeter style plates in the past..I like them over the Bar style. as they can flow more. at any time.
the finish on the NOS plates you will not see when installed..its like the paint stuck to the gaskets..that all it is... I am Running NOS plates (x2) in my set up.. and only using 100hp to 120hp hit.on ea plate (200 to 230ish).ran on EFI fuel presser. you can just make out a 90deg fitting (blue).. also both the plates in this pic. are in the same shape as the one pic i sent you..gaskets dont mess up the sides of the plates.. NOS is sort of a cheap paint..
cool, thanks for the pics and for the description. I think I am going to buy the NOS Cheater plate from ya.
It is good that the finish on the side is still in good shape, but I am probably going to paint it silver (only the sides of it, not the gasket surfaces). Everything on the top end of my engine is chrome, aluminum, polished, or silver in color, so a black plate would be out of place looking. I Did exactly this same paint job to the 1/2" phenolic carb spacer that I use too, and it blends in with the intake and holley sniper unit just fine.
Anyways, I will send you a PM now, and we can arrange payment, shipping, etc. Thanks!
I just wanted to say that I received my parts today and everything is exactly as described. I would definitely do business with articwhitez again. Honest, responsive and received my parts faster than expected. Thanks!
Originally Posted by zman1969
I had asked about smog delete pulley and bracket and you were trying to locate it - now i see you have another thread selling one??
was thinking you would check back.. I have a lot of guys asking for parts..
I do have another one..ill cut ya a few bucks off and do $70 shipped.. with paypal fees its $73.50 will get it out this week with alot of other parts.. NOTE" Off my car.. I used 2 smog delete brakets..as i could not get a A/C Delete the week i took off My A/C. I ran it like this for 6 years..
SO yes I have yet another ...Just for you...$70 shipped
If you have paid in the last 4 days. sat/sun/mon and today tue.. all parts will be shipped by Thursday (working to get it all out as fast as I can.) Wanted to give a heads up..
1.A piller with auto meter 2 Gauge pod (shipping Thursday 6/17/21) had to make a box...this is 54" long
2.1992 TPI Fuel rails & lines brackets and small parts also out by the 17th
3.Smog delete Brackets all out same day the 17th
