I have 1989 TTA I am converting from a high end drag car to a pro-touring car.
I have a complete QA1 suspension with spohn coil over Kmember.
I also have an aerospace front and rear disc set up
Spohn tubular k member for coil over we just pulled, for sbc, bbc and v6 with lower arms.
Also pulling full qa1 front and rear struts springs and shocks with mounts and rear lower arms and drag rear sway.
All very nice
All suspension for 1800.00
Front and rear aerospace brakes 1000.00
Not counting ship
I have a box that will hold it all minus rear sway and i have a box that will hold the rear sway.
I have afedex besiness account i can use to send ground and get you a quote
Re: SPOHN K MEMEMBER QA1 SUSPENSION AEROSPACE BRAKES
How old is the suspension items? k-member and front and rear shocks?
Curious what trans are you running.
Im taking my stock iroc z to, mild street strip car, Sold the Wild 1800HP race only iroc z, bought a stock one and now want to make it a little faster.
where are you located?
I can’t give you an exact date because it was built before I bought it. It was built and it was run a very few Passes and the motor was hurt. He had it rebuilt and sold it.
All the parts were strip only and no street driving
I will have a turbo 400 with a BOP bell housing built by Rodney at rpm. It is a very high end build and I will be selling it in the next couple of weeks with the spohn tenant mount
The rear brakes are non E-brake 4 piston for c clip 12 bolt axles.
The front are the heavy duty 4 pistons.
The fronts aren't in the pic theyre at my shop
