$1000 for the set, local pick-up Temecula, CA only.
L98 purchased from member f1ls1 in 2008 and stored since. f1ls1 description: "I have a 1990 L98 Remanufactured complete with injection. For $****.** The motor has never been run it's still in the crate. It is a .030 overbore .010/.010 crank has all new pistons, rings, bearings, Stainless steel valves with teflon seals, new valve springs, cam, lifters, push rods, oil pump and a rollmaster double roller timing chain. It was assembled using all GM gaskets not after market. The motor has all new sensors and the injectors were cleaned and flow tested. It also has a brand new GM water pump and flywheel."
