What L98?
Old Dec 5, 2007 | 08:15 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
What L98?
I am looking to get either an Lb9 5speed or L98 auto camaro/gta for my next project and I was wondering if there are any differences in model years that I should avoid? I am leaning towards a lb9 and replace the 5.0 with a procharged 5.7/t56 combo but it depends on what I run into out there...if I can get a great deal on a realy nice 5.7 auto I might go that way. Basicaly I just want to do alittle homework before I make a purchase and know what to look out for...example I dont want to buy an 89 l98 and find out a week later they had realy bad transmission problems, weak cranks, or what ever else, ect ect.
Old Dec 5, 2007 | 09:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: What L98?
There's no big issue to worry about.
If you're going to use the L98 engine, then you're one step ahead by getting a car with an L98 first, rather than swapping in a 350 to replace a 305.
However if you're going to use a procharger, then you'll probably be rebuilding the engine first anyway right?
Old Dec 5, 2007 | 09:16 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Re: What L98?
followed by the transmission
Old Dec 5, 2007 | 09:32 PM
4playta's Avatar
Car: 1984 Trans Am
Re: What L98?
I would like to get a lb9 so I could install a t56 and not have to install clutch pedal and what not because it would already be a manual...but if I find a good deal on a l98 car I will keep it an auto and yes motor, tranny will be rebuilt as well as install a dana 60 rear end. I was just wondering if there are and model years I should avoid like the plague. The motor swap would not be hard if going the lb9 to the l89 way as I can pick up a donor 89 camaro with l98 for cheap right now...as much as I would like a t56 I am leaning toward a l98 to begin with though.
Old Dec 5, 2007 | 11:10 PM
Car: 1986 Iroc-Z
Re: What L98?
yeah starting with an l98 car would be a good start. I am always worried when i see a t-top l98 car without subframe connectors because of all the torque those motors have. i myself would be more willing to buy a 305/t5 car to build and the l98 car for parts. i like alittle assurance. it sounds like you have the right idea though. if you can get the car cheap definately go for it or you may end up kicking yourself in the rear later. keep us updated.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
