L98 Vette 6spd in camaro
Old Aug 12, 2003 | 11:40 PM
Akshay's Avatar
Would the L98 corvette's 6spd. transmission (and bellhousing)bolt-up to a 350 Camaro/Firebird?
Akshay
www.geocities.com/akshay95624/index.html
Old Aug 13, 2003 | 03:38 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Excuse my ignorance here... But what years did an L98 vette come with a six speed?
Old Aug 13, 2003 | 06:19 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I dunno about years, but they did use the ZF 6-speed in some of the C4's. It'll bolt right up to a 3rd gen engine, but fitting it in the car might be a bit of an issue. I know it can be done (they built some of the Firehawks with ZF-6's I believe) but it'll probably take a good bit of fabbing.
Old Aug 13, 2003 | 06:52 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
89-91. In 92 they got the LT1 with the same trans. It will bolt up but it is easier and likely cheaper to do a T56 swap. I also believe the shift quality is better with a T56. There are also aftermarket crossmembers for 3rd gen T56 swaps. The T56 is also lighter than the ZF box. Last but not least, replacement parts for the ZF are expensive and hard to get.
Old Aug 14, 2003 | 09:55 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Ahhh... I remember reading something about that now. Thanks for the refresher.
Old Aug 14, 2003 | 10:20 AM
bigals87z28's Avatar
Car: Check The Sig
Plus, the ZF i belive is harder to find then the T56...
Old Aug 14, 2003 | 10:59 AM
TheGreatJ's Avatar
I think it's also supposed to be slightly stronger....but the T-56 is factory underrated at 450ftlb. If you're makin too much power for a T-56 then you need to be running a TH400 or something.
Old Aug 15, 2003 | 02:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Rebuilding a ZF is more expensive and more complex than a T56. And the transmissions themselves & clutches are more $. Skip it.
Old Aug 15, 2003 | 02:25 PM
Car: Check The Sig
how about a 4+3!! anyone do that swap?
Old Aug 15, 2003 | 02:26 PM
jmd's Avatar
jmd
Sure, people have done it. It's just a B-W Super T-10 with an unreliable O/D unit. Go Richmond instead and save yourself headaches.
Old Aug 15, 2003 | 05:36 PM
TheGreatJ's Avatar
The 4+3 is one of the most amazing tranny's out there. Amazing how much of a pain in the a$$ it can be, that is.
Old Aug 15, 2003 | 10:26 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
What is a 4+3 anyways? I have heard it before but don't know for sure what it is
thanks
Old Aug 16, 2003 | 12:05 AM
Tom84L69's Avatar
Car: 84 Z28
A T10 with an overdrive attached. It gives overdrive in 2nd, 3rd, and 4th gear...making it a 7 speed. I don't know why everyone bashes this trans. My friend races C4 Corvettes using the 4+3 exclusively, and it never lets him down. It also gives him the advantage of 7 speeds, very valuable on a road course.
www.djrace.com
Old Aug 17, 2003 | 09:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The TPI vettes were from '85-91 I think... '84 they had the 350 CFI and '92 they got the LT1
Old Aug 17, 2003 | 11:37 PM
Car: Check The Sig
dont forget the 83 vettes that had nuclear reactors.. they were very unstable and destroyed every single last 83 vette... except for one they put CFI in... 83... crazy year...
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
matthew911
Aug 12, 2015 09:38 AM
