[Sold] World Class T5 setup
Old Aug 22, 2024 | 09:58 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have a world class T5 setup. 2.95 first gear, .63 fifth. No pedals included, but I have a bunch of NEW stuff to get you going!
Bell housing (used original OEM)
New Pro 5.0 shifter
New master cylinder
New slave cylinder
New clutch fork
New throw out bearing
New pilot bearing
New reservoir bracket
You'll just need pedals, flywheel + clutch, and a reservoir.
I'm swapping to a TKX so this is for sale. I'd like to sell it all as a package deal. $1,000 or best offer.
I'll be at the New England Dragway swap meet this Sunday 8/25 if you are local.
Old Aug 26, 2024 | 04:10 PM
Edsiroc's Avatar
Car: 1989 Camaro, 1989 Firebird
Engine: 5.0 TPI, 5.7 TPI
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.23
Re: World Class T5 setup
Man wish I was closer and this deal came up a month ago! GLWS!
Old Aug 26, 2024 | 04:45 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Still have it? Or'd you sell it at Epping?
Old Aug 27, 2024 | 09:38 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Still have it. A few guys looked at it but asked if it would work in their S10.
I did sell some stuff though, so the day wasn't wasted.
Old Aug 27, 2024 | 01:17 PM
Engine: LT1, L400
Cool that you were able to move some stuff. I might be interested in the trans, for the Kart....100 lbs savings over the ZF6 assy. I'd have to get a friend to go pick it up from you.
Stewing.....
Old Aug 27, 2024 | 03:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Stewing.....
You gonna use a l98 vette bell housing or the fbody one?
I put a T5 in my '87 vette years ago. I worked with Tommy to build the Cbeam adapter at the time. Fun stuff.
Old Aug 27, 2024 | 09:55 PM
Engine: LT1, L400
I’d use all F-bod everything. Except for the master cyl and pedals. I’d have to copy what you did making a c-beam device.
Car is getting a 400 next, so a T5 makes the flywheel easier, too.
Old Aug 27, 2024 | 09:59 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't think you can fit a 168 tooth flywheel in a F-Body t5 bell housing. You'd have to check but I think 153 tooth only.
Old Sep 3, 2024 | 09:13 AM
Engine: LT1, L400
I agree. I'd use F-body everything...FW included.
I already have a T5 w/shifter and BH, but it's not a WC and it's not the .63 OD...so I have it...but don't "down" on it.
Old Sep 11, 2024 | 03:35 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Tom, don't go with stock 85 flywheel + 400 balance plate in case you had considered. Starter pinion / ring gear get chewed.
Joe, best LC9 / swap build thread for yours?
Old Sep 11, 2024 | 07:58 AM
Engine: LT1, L400
Huh?
Old Sep 11, 2024 | 02:28 PM
jmd's Avatar
jmd
Huh?
Your above posts indicate you planned a 400 and F-body T5 setup. Get the flywheel already balanced for a 400. Not a stock 305 replacement with balance plate.
Old Sep 11, 2024 | 05:07 PM
Engine: LT1, L400
Copy. I've done it both ways...both worked fine, but getting it balanced to "400 Spec" is cheap/easy.
Mongoose
Feb 11, 2015 11:55 AM
sfmaro
Aug 31, 2009 08:34 PM
beardy2
17
Oct 24, 2008 07:12 PM
FstBrd6point3
Oct 23, 2006 03:58 PM
