T-5 Tranny set-up
T-5 Tranny set-up
Have a T-5 swap set up. all parts have 70k miles on them. Transmission with shifter, flywheel from a 305, clutch pedal set-up, master cylinder and crossmember. All you need is a new clutch and you're good to go. Dont want to seperate, would rather sell as a kit, but make me an offer and we can go from there. pics upon serious inquiries.
chris
203.808.2525
cdezinno@uci.edu
chris
203.808.2525
cdezinno@uci.edu
Car: 1982 Trans Am
Engine: Chevy 305 for now
Transmission: Borg Warner T-10
T-5 SETUP
HEY BUD GOT YOUR MESSAGE THAT IT IS HYDRAULIC, BUT DOES IT COME WITH EVERYTHING I WOULD NEED TO CONVERT MY 1982 T/A TO A HYDRAULIC SETUP DO YOU KNOW? i HAVE THE T-10 4SPD AND WANT TO CONVERT TO A 5SPD. THANKS
I have:
the transmission
the flywheel
the Pedal set-up
the 5-speed master cylinder
and a new slave clylinder
as to your question, I have no idea, you'd have to ask on the tranny board. I do know wou will need a clutch and pressure plate. all I know is it was everything I needed to convert my 700r4 to t5, I just never did it.
the transmission
the flywheel
the Pedal set-up
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Is the tranny from a tbi or tpi engine (only difference is the overdrive ratio)?
Car: '91 Formula
Transmission: 700-R4
If it does not need any work on it and ready to go, I would seriously think on taking it for $250 plus shipping. Can you estimate shipping to 98203 ?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
