22# or 24# Injectors
Old May 17, 2006 | 04:22 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I need a set of stock 350 TPI injectors or another set of 24# injectors for my 383 until I can get it tuned. I can't spend a lot, they will be on the car a short time hopefully but they do all have to work properly.
I've had enough problems with this motor so far I need some that I can count on to work for me.
thanks!
Old May 17, 2006 | 04:37 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I have a set of slightly used 24# they're the ford style and need new o-rings, they worked fine when I took them off the car. If your interested let me know.
Old May 17, 2006 | 04:39 PM
age's Avatar
age
Car: 1992 Z28 1LE
I have a set of oem 350 injectors.. how much you willing to spend?
Old May 17, 2006 | 04:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Hey all, I'm not looking to spend a ton because I have a set of SVO red tops but apparently they are too much without a tune and I'm washing down my walls as well as ruining many many plugs...
I've been through so much pain with this motor I'm alomst done with it altogether. If this motor is even still good (gotta see if this metal in the oil is death) I'm looking to spend around $40 for a working set. I just wish I hadn't given mine away to someone on here.
You all can PM me or Email me at camaroman@insightbb.com as I'm on the computer pretty frequently.
Thanks!
Old May 21, 2006 | 08:13 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
i have a set of what i think are 22lb injectors from a 87 iroc. they are oem. $35 + shipping from atlanta
Old May 21, 2006 | 09:12 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks for the offer but I think I've decided to stick with my 30's and try to actually tune the car!
thanks anyway
Old Jun 1, 2006 | 01:45 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
thanks anyway
You're chip is on it's way. If it's too rich/lean, lemme know and i'll mail you out another.
-- Joe
Old Jun 1, 2006 | 05:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
