Need 3.23 or 3.42 ring and pinion from 89+ thirdgen rear
Old May 30, 2006 | 07:46 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Need 3.23 or 3.42 ring and pinion from 89+ (2 series carrier) thirdgen rear in good used condition for my 89 Camaro IROC-Z 2.73 POSI disc rear.
Make offers, have cash in hands
Old May 30, 2006 | 08:14 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have a set of 3.23's from a 92 RS in good shape. $50 shipped for whole assembly. I may have a set of 3.42's from an 89 2.8 5 speed car $65.00 shipped for whole assembly. i will not seperate ring gear from pumpkin, it all gets sent as a complete assembly...........jt
Old May 30, 2006 | 08:18 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Do you know if the 3.42 will fit my car easily?
I'm no mechanic so...
I was told 89+ thirdgen all have 2 series carrier and should fit my rear better than let's say 88- thirdgen.
Old May 30, 2006 | 11:15 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
someone told you wrong... if you car has 3.xx or numerically higher gear it is a 3 series carrier if you car has a numerically lower than a 3.xx rear gear it is a 2 series. you can get 3.42 or 3.73's for a 2 series carrier but they are aftermarket parts.
Old Jun 2, 2006 | 12:56 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
I have a 3.23 gear and a 3-series posi that will be a direct swap for your stock gears. PM me if interested.
Old Jun 2, 2006 | 07:17 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Anyone else can confirm it will be an easy swap for me?
Old Jul 4, 2006 | 12:20 AM
Axle/Gears: 3.73:1
Not sure if you need someone else to confirm that they will work for you, but I still have the gears and posi if you are still in need of them.
Old Jul 4, 2006 | 01:34 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your close ----> You forgot about the 3.08 gears ( 2 SERIES ) that many automatics were equipped with from the factory !!!!
Don't expect that you can just pull your existing gears out and drop another set in their place. If you don't KNOW what you are doing you better let a pro handle your gear swap !!!
All these posts mean NOTHING if your looking for replacement gears for your ride !!!
Your Sig shows that you've got a 2.77 9-bolt !!! You HAVE to buy Borg Warner gears if your looking to replace your original gears !! 3.08's will fit your existing 2-series carrier; or you can find a 3-series carrier with 3.27, 3.45, 3.70 Ect.....
Old Jul 4, 2006 | 07:19 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
This thread is old, at the time I tought I had a 10-bolt... 9-bolts gears will not be as easy to find. Oh welll
Old Jul 4, 2006 | 09:41 AM
John in RI's Avatar
I'm pretty sure that I've still got a set of 3.27's in the garage somewhere...... I had them pulled when I got 3.70's installed. If your still looking just let me know and I'll try to locate them. ( I *Might* even still have a 3-series carrier as well )
Old Jul 4, 2006 | 10:47 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
If you still have everything to convert my 2 series to a 3 series 9-bolt I would be interested if the price is good.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
