NEED 88TPI and Speed Density harnesses
Old Jun 18, 2006 | 12:57 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
Im looking for an 88TPI and Speed density Firebird harnesses. For the 88 I just need the engine harness for the SD I need dash and engine harness.
Old Jun 18, 2006 | 02:22 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
thats a confuseing post you know that all 88s where mass air flow not speed density speed density was 90- 92 the interior harnesses are the same
Old Jun 18, 2006 | 03:51 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
To clarify.
I need a TPI harness from an 88
I also need a SD Engine and Dash harness from a SD Firebird
The dash harnesses were different in almost every year. Mainly in the fuel pump wiring. The C207 connectors need to match years or re-wiring will need to be done.
I need the 88TPI harness more than the SD. My 88TA is ready to run as soon as I plug it in. The SD harness I'm using for a turbo conversion in an 88 TBI formula. I have a painless that was given to me but its more of a PITA than painless.....Plus the factory just looks better to me.
Old Jun 20, 2006 | 05:28 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a 91 gta i can help with the body harness...just the inside harness, i also have a front head light harness from a 91 formula [ does not have fog lights] no engine harness...if this will help you at all....
Old Jun 20, 2006 | 07:06 AM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
How much you want for the dash harness......Is it complete from the C100 bulkhead in the drivers side firewall down over to the C207 ECM location?
Old Jun 20, 2006 | 07:40 PM
Transmission: auto
how does $150 sound shipped
Old Jun 20, 2006 | 07:41 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
Sounds good if you can wait till friday (Payday) PM me payment info. Thanks
Old Jun 20, 2006 | 07:47 PM
Transmission: auto
e-mail me for my address wtg3575@aol.com ...will take it out over the weekend...also the stereo harness is not cut either
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
