t-5 parts
Car: '82 Trans Am('88 GTA clone)
Engine: High output 305
Transmission: Turbo 350
t-5 parts
im putting a v8 t-5 on my 305 and i need the crossmember, bellhousing, pedals, entire clutch pedal assembly(cable and whatnot), driveshaft and maybe the starter(dont know if the one i had with my turbo 350 will work), computer and any wiring for the t5....if anyone can help me with any of these parts i would really appreciate it...the tranny came out of an 87 iroc i believe... so if im forgetting anything(first manual conversion ive ever attempted) also let me know... thanks
Car: 87gta 88gta 88marovert
im putting a v8 t-5 on my 305 and i need the proportioning valve, crossmember, bellhousing, pedals, entire clutch pedal assembly(cable and whatnot), driveshaft and maybe the starter(dont know if the one i had with my turbo 350 will work), computer and any wiring for the t5....if anyone can help me with any of these parts i would really appreciate it...the tranny came out of an 87 iroc i believe... so if im forgetting anything(first manual conversion ive ever attempted) also let me know... thanks
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
your going to have troubles with the crossmember why you ask ... 82 doesnt have inner bolts in the frame to mount the trans mount farther back for a t-5 changeover. its easier to weld a extension on to your 82's crossmember thats what I did to mine.
theres a hole in the firewall for the clutches master cylinder. theres like a metal plug that seals it you just tap it out. but you have to drill two small holes for the master cylinders U-bolt to secure it.
I used a 700r4 drive shaft for mine.
If you need a flywheel I have a real nice one and your stock starter will work with a 5 speed flywheel
also you will need a 700r4 or t-5 torque arm, your 82's is longer and when you try to cut it shorter it won't fit the bracket on the t-5 very well. heres everything you will need.
83-early 86 two piece rear main flywheel
84 up torque arm I used a 84 v-8 700r4 torque arm on mine
84 up bell housing
I used a 89 clutch pedal setup
all 84 up 4 clylinder - V-6 - and V-8 used the same hydraulic stuff
83-84 5 speed shifter plate
upper and lower shifter boots
84 up 700r4 or t-5 driveshaft I used one from a v-6 car with a 700r4
5 speed dash lower panel but you could cut yours out
also the v-8's use a heat shield around the hydraulic slave cylinder try to get one.
good luck
84 up bell housing
good luck
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
