T-5 Speedometer Connector needed
Old Sep 18, 2006 | 04:30 PM
Maroon89gta's Avatar
Car: 89 Trans Am GTA, 01 Ram, 01 Harley
Transmission: Worldclass T-5
I need a connector for the speedometer input on a Worldclass T-5 Transmission that came out of an 89 Trans Am. I swapped my 700R4 and the automatic and manual connectors are different even though the transmissions where of the same year. I am looking for the part or information on where to get the part. It is a discontinued item and can't be purchased from GM.
Old Sep 18, 2006 | 06:42 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Eletric VSS out of a 1988 Formula WC T 5. 30.00 shipped
Old Sep 18, 2006 | 08:15 PM
Just need the connector
I only need the connector. My new T-5 has the speed sensor. I just need to connect it to my automatic wiring harness that has a different connector. If you have the T-5 connector from a 87 to 89 manual Trans Am or firebird wiring harness, I will purchase that. Only 87 to 89 will match up.
Thanks for the reply
Old Sep 18, 2006 | 10:15 PM
buffaloman's Avatar
Hardness is sold complete. May be a hard connector to find as most sell the complete uncut hardness.
Old Sep 18, 2006 | 10:30 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
does your connector have yellow & purple wire. or is it the older style vss. I think they used two different connectors.
Ive got a 89 junk TBI harness and a 87 TPI harness. can you post pics of your speed sensor I should have the connector you need
Old Sep 19, 2006 | 06:59 PM
I'll Try to get a pic tonight. A local GM car dealer that sells parts told me that the T-5 connector was the same on 87 thru 89 trans Ams and Firebirds. I will try to get a picture tonight, but the connecter on the T-5 has two small spades and are on individual posts and looks like it locks on one side. Typical GM connector.
Old Sep 23, 2006 | 10:03 PM
Found my connector that I needed today on a junk 2000 camaro wiring harness. Installed it and everything is working great. My T-5 swap is complete.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
