Need 730 Memcal for 305 TPI
Car: 88 Olds Cutlass GT, 92 GMC Sonoma
Engine: 86 305 TPI
Transmission: TH-700R4
Axle/Gears: 4.10 10 Bolt
I am looking for a memcal for a 1227730 ECM, 305 TPI engine. I do not particularly care what the broadcast code is on the chip, as I will be using a Prominator--though an appropriate 305 .bin would be nice to start with. I have a 730 ECM, but it has a 2.8L memcal in it.
Semi-Related:
If someone knows of a good place where I can find an appropriate .bin for a 305 TPI, please let me know. There used to be a good database for this at www.efitune.com but the site seems to have disappeared. I know www.diy-efi.org has a nice selection of .bin files, but the last time I was there, they did not have a good way to indicate what the broadcast codes were for (ie 305 or 350, A/T or M/T, etc.).
Thanks,
Keith
Semi-Related:
Thanks,
Keith
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your local dealer should still have them, if not try the more famous online dealers.
You can start with an AUJP, its a '92 350 automatic, and just change the cylinder volume and injector constant.
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
