82-84 Fuel Tank Sending Unit.
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Hey guys,
My fuel gauge has stopped working and I know its not the wiring but anyways I need a sending unit. Other years might be the same but i'm not sure. lemme know if you have anything!!!
Thanks,
J.
Thanks,
J.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got one I can sell Ya'....... $45 + shipping.
There are 2 things I need to mention. First; It has no rubber gasket on it. ( You would need to use your old one ) There is a lock-plate but the rubber has gone AWOL. Second; the plug housing is gone. A new plug needs to be spliced on it. It's the correct length - but the 2 prong plug was busted. (It's a pretty common plug - I might even have one for it. )
I use this sending unit to test the gas guages on the clusters I sell to people and know that it ranges correctly from empty-to-full. It's been out of a tank for about 5 years. There are no blockages or kinks in the lines and the rust is not bad. I'm pretty sure it was originally in an 84'.
Include your ZIP code for a shipping qoote if your interested.
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
