WTB complete TPI setup
Old Jul 10, 2007 | 03:54 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I'm looking for a complete TPI setup for my camaro. I need the intake, TB, injectors, wiring harness, and PCM. TPI off a 350 would be best. Let me know how much.
Old Jul 12, 2007 | 06:11 AM
350sbcRX7's Avatar
Car: 1988 Mazda RX7
Engine: 350 L98
Axle/Gears: 4.11
Re: WTB complete TPI setup
I don't have everything you want right now.......BUT
I do have a TPI setup off an 87 Corvette for sale. TB, plenum, runners, and lower intake manifold. Also comes with the fuel rails, injectors and adjustable fuel pressure regulator. Intake boot from a Camaro and the MAF sensor.
$200 shipped.
You can find a wiring harness on the forum or else on ebay as well as an ECM.
I also have a Moates adapter and chip burner to make custom burnt proms for sale. $125 shipped
$300 shipped for all of it.
Old Jul 12, 2007 | 08:39 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I have a complete tpi setup i just pulled off my camaro. Comes with everything you need to hook it up. base, runners, plenum, tb, maf, iroc y(intake duct) with two brand new K&N filters, distributor, accell cap rotor and coil, fuel rail, injectors, gaskets, bolts, egr, water neck, most all sensors(I think cts is the only one missing.), wiring harness, and ecm. And if you are switching from a carb I will even include the fuse block I used to wire the injectors. Heck I'll even throw in the radiator hoses. Bottom hose is almost new. top hose might need changing soon. Everything for $550 plus shipping. PM me if interested.
Old Jul 16, 2007 | 05:57 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have a complete TPI from my 88 GTA, wiring, distributor, PCM, injectors, most of the sensors, descreened MAF, have a set of wires I could throw in, new set of gaskets and TB. I also have a set of button head stainless bolts to replace the stock torx head bolts. Would like $250 plus shipping
Old Jul 27, 2007 | 10:53 AM
89Iroc-ZTPI's Avatar
I have a complete tpi system with sensors runners base plate intake ,throttle body fuel rail etc. ill even give u a set of chevy 350 headers black jack for 400.00 ill even split the shipping cost with you . Ive got motors and stuff too ive got to get rid of cause im going back to the military. call ben at 248-413-9298
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
squiggy2
Aug 9, 2015 09:30 PM
