Stock TPI Runners / Plenum / TB
Old Aug 26, 2007 | 10:07 AM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Axle/Gears: Ford 9" with 4.30s
I have the base plate already, need everything that goes on top of it. This is for my DD, so nothing fancy, just stock stuff. Would be nice if it were in central FL so I could pick it up.
Old Sep 1, 2007 | 12:24 PM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Re: Stock TPI Runners / Plenum / TB
Come on, there is not a single person out there with freaking stock TPI parts??
Old Sep 1, 2007 | 01:23 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
What exactly are you after than, just the runners and plenum, or the runners, plenum, fuel rail, injectors, throttle body, etc? 350 or 305 matter? What are you looking to spend?
Old Sep 1, 2007 | 06:57 PM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Actually, I scored some runners earlier today and just now got a likely hit on fuel rails and plenum. So now all I need is the throttle body (from a 350, if it makes a difference). Price wise I'm going for the "budget" thing, ie as low as possible, but don't want to lowball anybody.
Old Sep 1, 2007 | 07:24 PM
Car: '87 Trans-Am
I was wavering back and forth on parting a '86 IROC Ive got, but you have the most of the parts you need and I would rather sell whole units/combinations when it comes to stuff like that, but I thought I would check. Also, I would have had a 305 setup, so it probably would have been a moot point anyway.
Old Sep 9, 2007 | 06:22 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There is no difference between a 305 & 350 TPI. There is a difference in the later years (1989 no longer had the Cold Start Injector aka the 9th injector) and 1990 up had a MAP sensor that attached to the plenum.
Old Oct 7, 2007 | 11:21 PM
doppler's Avatar
I have an 1987 350 TPI throttle body, I'd take $35 shipped.
Old Oct 8, 2007 | 10:03 AM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
PM sent
Old Oct 8, 2007 | 10:14 AM
doppler's Avatar
PM replied to.
tazs2000
Jul 15, 2017 08:44 AM
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
