87 IROC Wiring Harness Needed
Car: 1987 IROC Z28
Engine: 305/ 5.0
Transmission: 5spd Auto /700R
I need the complete engine compartment wiring harness for an 87 IROC Z28 with 305 / 350 engine, air, cruise, TPI, 700R4 auto trans, etc. I need a good harness, nothing that's been hacked into.
Geno.
Geno.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: 87 IROC Wiring Harness Needed
I have a pretty nice 87 ecm harness (I think will have to check the distributor connectors to be sure) It needs like two connectors but its a easy fix ... does your car have the small distributor with external coil?
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
I have a complete harness just removed from a 1987 z28..made no cuts..looked unmolested-$150 shipped
Car: 1987 IROC Z28
Engine: 305/ 5.0
tpi-hearse, please check your PM.
Geno.
Quote "I have a pretty nice 87 ecm harness (I think will have to check the distributor connectors to be sure) It needs like two connectors but its a easy fix ... does your car have the small distributor with external coil?"
Thanks, but the ECM section is the one portion that hasn't been spliced into. Do you have the A/C portion of the harness?
Geno. <!-- google_ad_section_end -->
Geno.
mustangman65_79
Aug 11, 2015 03:17 PM
