heads and a cam
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
heads and a cam
Im looking for a set of heads from a 350 with at least 1.94int valves that will work on a 1991 throttle body injected small block. Im also looking for a cc-306 cam or somthing close to that, thanks and please pm with offers
Re: heads and a cam
i have some edelbrock 6085's
only have 3k on them. 2.02 1.60 valves, ported, .600 springs, 7/16 studs with guides. centerbolt covers, 60cc 165cc runners.
let me know!
call me at 262-483-8969
or danziroc383@yahoo.com
let me know!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: heads and a cam
Your 91 Z28 is a tuned port injected small block, not a throttle body. Are you looking for parts for a different car?
A 305 cant use 2.02 intake valves. They're too big and will hit the cylinder walls. Also, the CC306 is way too big for a TBI and is large for 305 TPI engine as well with out major custom programming to the computer.
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Re: heads and a cam
yeah there for a different car. What about an Lt4 cam and l98 vette heads? Or just a basic factory small block head with 1.94's in it? Thanks
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: heads and a cam
I have a set of '71-'72 LT-1 heads if you are interested. I think they are 1.94, it's been a while since I looked at them. They have been redone in the past, but I would recommend they be checked out/ new seals.
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Re: heads and a cam
I got a set of TBI 350 swirl ports that I took off a running motor. They can make power if you want to spend the time on them
You pay shipping plus 30 bux and they are YOURS
Also best place to find you a cam is Federal Mogul, or speed pro. they copy alot of "specialty" cam grinds and sell them for way cheaper
Guest
Posts: n/a
Re: heads and a cam
zz4 cam and ported l98 heads with lt4 valve springs if interested, irocdyou@hotmail.com
Transmission: t-5
Re: heads and a cam
i have a set of brodix 11x heads with a matching cam. Also includes retro fit roller lifters, 1.6 roller rockers and harden pushrods. I have all the paper work and less than 1k from a freshen up. call if you interested and want more info. 262 745 2432 my name is jerry. asking 2000
ambainb
Apr 25, 2016 09:21 PM
