Throttle position sensor
Old Oct 8, 2007 | 08:53 PM
Kevin Knight's Avatar
Car: '82 & '84 Trans-Am
Engine: LG4 305 & L69 305 H.O.
Transmission: TH200C & 700 R4
Axle/Gears: 3:23 & 3:73 10 bolt
Does anyone have a throttle position sensor, for a '84 305 H.O.? Also need the bracket, and screws if possible. This is obviously for a computer controlled 4 barrel rochester. Thanks.
Old Oct 9, 2007 | 09:29 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Throttle position sensor
Just a heads-up, Kevin. The TPS is very sensitive to moisture. Many people have taken them out by washing the engine compartment at the car wash. Be sure that the person you buy from didn't wash the motor with a high pressure washer prior to pulling the engine and selling you the TPS.
Old Nov 15, 2007 | 05:56 AM
Thanks dude, I will remember that, I did not need the TPS afterall, my new carb already had it, I had the throttle position sensor confused with a idle solenoid all this time, lol. Thanks again.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
