Need a 350 or 400 block
Old Jan 9, 2008 | 08:46 PM
moose5.7's Avatar
Car: parts of an '83 Z-28
Engine: disassembled and scatered about
Transmission: sitting on the shop floor
Axle/Gears: two of them
I'm looking for a bare or short 350 or 400 that is rebuildable. Something within a 200 mile radius of Charlotte, NC. I gotta wake up my '83...
Thanx, Moose
Old Jan 9, 2008 | 09:50 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: Need a 350 or 400 block
Take a look at this 350 block I have for sale: https://www.thirdgen.org/forums/engi...piece-rms.html
Old Jan 10, 2008 | 08:43 AM
sngreen1's Avatar
Car: 1984 z28
Transmission: t-5
I have Two 4-bolt blocks and a two bolt block, all have been bored, honed, new cam bearings, and freeze plugs installed. PM me if you would like more info! thanks steve
Old Jan 10, 2008 | 04:37 PM
moose5.7's Avatar
pm sent
Old Jan 20, 2008 | 01:21 PM
jimlt4383's Avatar
i have a 350 1 peace seal factory roller cam short block with a spun rod bearing and a good extra crank. do you still have the vortec heads ? we mite can work out something. i am in salisbury nc just up i85 from you. also have house in south charlotte but engine is in salisbury.
Old Jan 21, 2008 | 07:40 AM
moose5.7's Avatar
Thanx but i've allready traded the heads for a block
Old Jan 21, 2008 | 07:39 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
i don't have a block for you to use but if you are interested i have a good rotating assembly from a 406 that is all in good shape. the crank was recently polished and the wrist pins were replaced. Has aluminum pistons. I have no use for this stuff because I need a more substantial rotating assembly for what i'm building now.
Old Feb 23, 2008 | 03:19 PM
randyh68's Avatar
Want a title? Post!
i am looking for a 4 bolt 350 block. How much for one of yours?
randy
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
lakeffect2
Aug 23, 2015 08:44 AM
