SD TPI harness
Old Mar 3, 2008 | 10:48 AM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
SD TPI harness
I need a complete, un-cut SD TPI harness for a Camaro (Ive heard they're different from Firebirds). Im not in a big hurry to get one, but Im gonna need to get one within a month or so. Ill throw on an extra $30 if the connectors are labeled!
Old Mar 4, 2008 | 03:17 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Re: SD TPI harness
I got one couple wires are cut but real easy to fix. Coil positive wire and tach wire cut, canister purge solonoid wires cut, egr solonoid wires cut, tps wires cut and the fuse holder for the fans by battery were cut. ....... Easy to fix came from a 1992 350 Z-26 ....... wiring for dual fans is there real nice harness take you maybe a hour to fix the wires or I can and charge extra for the harness.
Old Mar 14, 2008 | 09:18 PM
Damani37's Avatar
Car: 1987 IROC Z
Engine: 5.7 TPI
Transmission: 700R
Re: SD TPI harness
do you still have the dual fan wiring harness? I need ! for my 87 iroc 5.7 350. Also what does the fuse holde look like by the battery? I may need that too?
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
