OEM G92 DUAL CAT Y-PIPE NEEDED!
Old Mar 27, 2008 | 02:08 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
looking for a lil bonus on my gta , im requesting the G92 dual cat y-pipe oem style , with or without cats i just want the oem fit and function
Old Oct 14, 2008 | 10:07 AM
b4c-1le's Avatar
Car: "92 RS Camaro B4C/1LE 25th Anniv.
Engine: L98 w/corvette heads & ZZ4 cam
Transmission: built 700R4 with Hughs converter
Axle/Gears: 3.23 posi w/1LE brakes
Re: OEM G92 DUAL CAT Y-PIPE NEEDED!
Magnaflow makes the only reproduction of this....it's actually a nice set up pre-welded with high flow dual cats and the air tubes. It's a bolt in and looks similiar to the factory unit at a fraction of the originals cost. Flows alot better too as it has larger diameter pipes and a better designed merger y-pipe. You can get it on e-bay for about $400... I know someone makes a non-cat version too, but I can't think of who it is...
Old Oct 14, 2008 | 10:57 AM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Catco has one too. Part number is 4153
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
onefreakz
May 14, 2018 12:15 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
