tpi for 91 z28
Old May 17, 2008 | 12:45 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
tpi for 91 z28
I am needing a tpi unit for my 91 z28 need plenum,runners,fuel rail,intake,throttle body,,,and comp if u have it must be able to fit my 91 305 not looking to swap heads...
steve
Old May 17, 2008 | 04:27 PM
Camfire's Avatar
Re: tpi for 91 z28
Hello,
I have the whole setup from a 90 T/A $475.00 shipped let me know thanks,Dave 716-445-0259
Old May 17, 2008 | 04:37 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: tpi for 91 z28
475 is bit much for me I already have the harness and distributor
Old May 18, 2008 | 03:53 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: tpi for 91 z28
i have 2 set ups one both off my 88. one is off my old 305 includes intake, plenum, runners, i19lbs injectors, stock throttle body with iac and tps, i believe the intake boot, fuel lines. second is off a 350 pretty much the same on it except it has 22lbs injectors, make me an offer im just looking to keep one tpi set in case i ever go back to tpi again as im curently doing a hsr swap, i know for sure u need a 9th injector block off plate pm me 4 any ?'s
Old May 18, 2008 | 06:39 PM
Steve86TA's Avatar
Car: To many to list
Re: tpi for 91 z28
pm sent.I have a setup from a 91 Z for $300 shipped with ecm.No wiring though.
Old Jun 11, 2008 | 04:51 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Re: tpi for 91 z28
I have a complete setup, polished runners, everything, harness, ecm everything. Came off a 1989 350... 350 shipped Check out my cardomain in my profile to view images
1992rs/ss
Jan 31, 2025 05:10 PM
diana227vegas
Jul 8, 2016 12:27 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
