Need T56 3/4 syncro hub
Old 06-12-2008, 04:22 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I'm in need of a 3/4 syncro hub for a T56. Only need the hub, not the slider. Went to press my hub off and found a crack in mine.
This can come from any model T56, this is the same part in any T56 trans.
Old 06-13-2008, 12:37 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: Need T56 3/4 syncro hub
I'm pretty sure I have one laying around do you know how to identify it because I'm pretty sure it's laying in a box with another syncro.
Old 06-29-2008, 01:15 PM
alloy's Avatar
Car: 87 IROC-Z28
Sorry I've not posted sooner. I never got an email telling me there was a reply to my post. After a few days I found one at Hanlon motorsports.
Now I'm looking for a dummy trans to check my cable mod conversions with. I need the front trans plate, input shaft with bearing, main case, output shaft with 1-2 gears and rear bearing. Don't care if gears are bad, just need enough to hold the main shaft in place and check tooth engagement. I'm using my trans for this now, but I'd really like to get the T56 in my car!!! Went to all this work and now I can't use it
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
meeklay812
10-01-2015 03:46 PM
gord327
09-29-2015 10:18 PM
dbrochard
Wheels and Tires
09-25-2015 05:40 PM
Quick Reply: Need T56 3/4 syncro hub
