Needed TPI IAC plug from engine harness
Old Jun 22, 2008 | 11:12 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Hey, anyone out there have a scrap harness with a good IAC plug on it? I need the square 4 wire plug for my 1990 tpi. Mine is in bad shape and I think it may be giving me idle issues . I just need the plug with enough wire left on to strip and attatch to my harness.
Or does anyone know of anywhere that sells the plug?
Old Jun 22, 2008 | 11:20 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: Needed TPI IAC plug from engine harness
I get all my connections from 1 of TGO's sponsors. http://www.eficonnection.com/eficonnection/default.aspx
I also believe you can get them from TPIparts also.
Old Jun 22, 2008 | 11:25 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I actually just found one. I did a search here for IAC plug and came up with nothing. After I made this post I had the brainstorm to look for IAC connector
Found a part number for one on yearone.com
Thanks for the info though, I just hope yearone ships to Canada.
Old Jun 23, 2008 | 06:40 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I found one on advanced auto parts website.....http://www.advanceautoparts.com/
Dorman 4-Wire GM Idle Air Control Valve Harness: Conduct-Tite!(R)
Part Number: 85112
For Your Vehicle
Vehicle: 1988 PONTIAC FIREBIRD TRANS AM
Engine: V8 5.0 Liter FI
Idle Air Control Valve Pigtail/Connector:
Retail Price: $25.61
Our Price: $19.99
You Save: $5.62
____________________________________________________________________________________________
This one was on autozone's website http://www.autozone.com/home.htm
Connector - Idle Air Control Valve Duralast / Connector - Idle Air Control Valve
for a 1988 Pontiac Firebird
Part Number: 239
Weight: 0.079 lbs.
Pricing:
$16.99
you can even try www.rockauto.com or www.tpiparts.net as well.......
Jorlain
Aug 24, 2022 05:11 PM
IROCZ1989
Jan 24, 2016 03:55 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
