Wanted Exhaust Manifolds & Y-Pipe
Old Apr 25, 2009 | 06:55 PM
MC87SS's Avatar
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Trying to complete a budget V-6 to V-8 Swap for my son.
Need a set of stock Exhaust manifolds & Y-Pipe or cheap headers.
Looks are not important just functionality.
No polution control required.
Need to be willing to ship to Florida 32333.
Old Apr 28, 2009 | 12:27 PM
mavsdad's Avatar
Re: Wanted Exhaust Manifolds & Y-Pipe
I have stock manifolds and Y pipe off an 87 Iroc. How much are you looking to spend.
Old Apr 28, 2009 | 07:38 PM
MC87SS's Avatar
Engine: 305/350/454
As little as possible.
Throw out a number shipped to 32333.
Old Apr 29, 2009 | 06:44 AM
mavsdad's Avatar
do you need the cat as well. It is welded to the y pipe if I remember correctly. I will see how much it is to ship.
Old Apr 29, 2009 | 11:21 AM
MC87SS's Avatar
Engine: 305/350/454
No cat needed, it can be cut off before it.
Old May 1, 2009 | 09:03 PM
mavsdad's Avatar
I had surgery today so it will be a little while before I can ship it.
Old May 6, 2009 | 04:15 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
I have a set of manifolds off a 86 camaro 305. If you are still needing a set. Let me know.
Old May 6, 2009 | 07:42 PM
bygblok's Avatar
if you can come across the manifolds I have a complete exhaust from my 92V-8 rs car that you can have for $100 if you'll drive to P'cola to get it. I've got the y-pipe, cat, and a dynomax 2 1/2 catback system complete with hangars and all. I cut the pipe right before the axle to get it off but that's the only thing that's been altered at all. It has real nice mellow sound to it and still breathes better than the stock stuff. It only takes a couple of hours to drive up this way from the 'hassee............ I also have a bunch of mounts, a k-member, stock springs, steering box, centerlink...you name it in the front end and I have it. Still have all the stock front brake parts too. I'm doing an LSx conversion and used all tubular stuff on mine and swapped over to Aerospace brakes as well. I also still have the stock ecm for the car if you're doing a throttle body. All the A/C, harnesses, radiator, etc has been sold but I still have a storage room full. Give me a shout!
Old May 6, 2009 | 08:34 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
i have some manifolds also i can get..60 shipped...also how did you go about getting the bottom bolt off of the v6 motor mount..I'm in a predicament with it
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
timonator
Aug 11, 2015 09:56 PM
mustangman65_79
Aug 7, 2015 09:55 PM
