[ND] WANTED: Flywheel, Clutch, Bellhousing, Pedal assembly
Old Aug 31, 2009 | 09:59 PM
89Firebin's Avatar
Car: 89 Firebird Formula 350
Engine: 1974 350
Transmission: '84 Trans Am T5
Axle/Gears: Borg warner 3.27
Hi, I am doing a 5 speed and motor swap in my 89 Firebird Formula
I am getting a transmission from an 85 Camaro
also a 350 SBC from a 75 3/4 ton pickup
I need the following things:
-153 tooth 5 speed flywheel for the 85 or older 2 piece RMS SBC motor. I can get a new one from summit racing for $82.90 shipped.
-82-92 clutch disc, pressure plate. I can get a new clutch set from summit racing for $109.64 shipped which has throwout bearing, pilot bushing, etc.
-84-92 clutch/brake pedal assembly
-84-92 hydraulic bellhousing with fork and boot
Contact me if you have anything with prices shipped to 58258.
Thanks,
Ryan
Old Sep 2, 2009 | 09:39 PM
1b rock's Avatar
Transmission: a4
Re: WANTED: Flywheel, Clutch, Bellhousing, Pedal assembly
i just got an 89 5spd im goin to part out
Old Sep 2, 2009 | 10:02 PM
89Firebin's Avatar
Engine: 1974 350
Ok,
How much do you want for everything listed above, except the flywheel, (89 is a 1 piece RMS) shipped to 58258?
Thanks,
Ryan
Old Sep 4, 2009 | 04:50 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
well i have a t5 clutch from an 86 lg4 car with bgw t5. clutch disk and pp have 38k miles on them.
also have a flywheel from the same car not sure if mine was an early or late model year but i think mine was a 2 peice rear main would have to check though.....
anyways i'd let the clutch and pp go for 15 plus whatever shipping would be. the flywheel i'd let go for 25$ plus shipping. if interested pm me.
Old Sep 5, 2009 | 09:43 PM
89Firebin's Avatar
Engine: 1974 350
Ill have to pass because the flywheel from the 86 is for a 1 pc RMS, and I think I am going to buy the clutch kit from summit.
Thanks for the reply though.
Ryan
Do you have the bellhousing?
Old Sep 15, 2009 | 08:43 PM
89Firebin's Avatar
Engine: 1974 350
bump
Old Sep 17, 2009 | 06:18 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
i have a bellhousing
Old Sep 17, 2009 | 06:20 PM
89Firebin's Avatar
Engine: 1974 350
PM sent
Old Sep 18, 2009 | 10:04 AM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
I have a complete v8 T5 trans, also have the pedal assembly. no flywheel or clutch though. not sure if I want to separate the bellhousing from the trans as someone might want the entire setup.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
6speedIROC
Sep 13, 2015 01:29 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
