[IN] Looking for shocks and springs
Old 01-06-2010, 08:24 PM
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
Hey guys, here's my deal. I've got an 87 Formula in desperate need of new shocks/struts, springs, and strut mounts. My driver front strut mount is completely shot and so are my rear shocks.
I'm actually wanting to lower the car a little bit but don't think I can go passed 1" because of my 3" exhaust pipe under the passenger side of the car.
I'm looking to see if anyone on here has a set up they used for a while but decided to change. Let me know what everyone has. If I don't find anything on here I'm probably just going to get some Moog springs and some factory replacement shocks/struts. But if I went that route I would like to find a nice set of some used front upper strut mounts. I don't feel like spending $120 on a pair from Summit. Seems a little ridiculous.
Thanks guys!
Old 01-06-2010, 08:41 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Looking for shocks and springs
Thanks guys!
if you dont want to spend $120 on stock style strut mounts, i wouldnt lower the car because you will need to install spherical type mounts that allow more strut travel and they are in upwards of $220-270 and are needed unless you want to replace your front struts every 6 months.
Old 01-06-2010, 08:44 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
I just bought a set of koni Yellows so the KYB's I have on the car now will be coming off shortly. they are the silver ones and are still in good shape.
Old 01-06-2010, 08:49 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i have a whole tokico performance shock strut spring kit. 1 1/4 drop, and there blue series shocks and struts. have less than 7k on them and i went to a drag shock and spring setup. i even have the upper strut mounts from the car
$300
Old 01-06-2010, 08:50 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
also... this car had a 3" exhaust system and it was just fine....
im in indianapolis indiana btw
Old 01-07-2010, 07:54 AM
Pistol Pete's Avatar
Car: 87 Z-28
Transmission: Automatic 200 Metric Turbo
Axle/Gears: Strange Axles & 5.14 Gears
I have a stock gm strut/shock from my 87 Z-28.
I set my car up as a drag car only.
I also have a set of stock gm front springs too.
The car only had 60,000 miles.
Asking: $20. for shocks & $20. for springs
Pac J
05-17-2020 10:44 AM
92projectcamaro
12-08-2015 12:25 AM
darwinprice
17
10-11-2015 11:51 PM
loud91rs
10-05-2015 10:05 PM
meeklay812
10-01-2015 03:46 PM
Quick Reply: [IN] Looking for shocks and springs
