Serpentine Smog Delete Pulley
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: Serpentine Smog Delete Pulley
You remove the smog pump what's the smaller belt size?
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
napa PN 660-1806
Dorman # 34157
You can use these numbers at any parts store Called A/C delete buts its the same pully
Shucks has them just give them the PN
Dorman # 34157
Those are belt numbers? I dont want a pulley, sorry your wording confuses me.
Can't you just remove the smog pump and use a smaller belt ? vs buying a delete pulley and running the same size belt?
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Actually on my Camaro, I took the pump off and just rerouted it and I didn't havta change the belt at all, now i dont know if the previous owner had a smaller belt on for some reason but i used the same belt
Here a pic of how to reroute the belt compared to a stock setup, just ignore the bottom setup.
Really? They are the same pulley? It doesnt look the same.
Edit....I have a A/C delete pulley, it doesnt fit in the smog pump bracket.
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
You cant go shorter you have to go with a longer belt otherwise it wont work. I have it done to my car, the belt is nice and tight with no vibration or wobbling even with the engine revving @ 5k down the track. Read the thread posted above, it even says go longer.
Sucks said they were the same pully. I ahve not had a chance to order one yet. Just been busy
Car: 92 Camaro RS
Engine: 305 TBI
It depends on how you have it routed, if i put a longer belt on mine it wont be tight at all.
If your jus wanting to put a delete pulley on here's a couple for sale: http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
http://www.hawksthirdgenparts.com/ca...etepulley.aspx
Why cant you remove the smog pump and run a shorter belt? The guy at mopac in edmonton told me that you can do that
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Car: 92 Camaro RS
Engine: 305 TBI
You can, for the pulleys I bought I was told I might have to buy a smaller belt but I didn't have to. My friend put a set on his bird and he did, you jus havta reroute the belt and see how much tension it has in it.
Car: 92 Camaro RS
Engine: 305 TBI
Car: 89 Iroc-Z
hey, sorry been busy. I'll get some pics tomorrow. It is the same as carfreak614 has linked. You can have it for 50 shipped. John
