WTB: complete TPI system
Old Mar 8, 2010 | 05:06 PM
91Camaro_RS's Avatar
I need everything to convert my Carbed 305 to TPI, let me know if you have a complete set up
Old Mar 8, 2010 | 06:18 PM
1990s10's Avatar
Re: WTB: complete TPI system
ive got a 305 tpi motor with ecm harness etc etc. let me know if u are still looking 54k on egine
Old Mar 8, 2010 | 06:19 PM
yup still lookin, how much for everything needed to convert?
Old Mar 8, 2010 | 06:21 PM
1990s10's Avatar
im assuming you want ecm, harness and tpi unit with intake? what all do u need?
Old Mar 8, 2010 | 06:25 PM
i need ECM, Harness, runners, intake manifold, plenum, injectors, fuel rails, sensors, distributor, throttle body, MAF, and im not sure if im missing anything, pretty much everything from the intake manifold up
Old Mar 8, 2010 | 06:28 PM
1990s10's Avatar
so essentially u are needing everything but the heads and block? let me ask u what u r looking to spend and maybe we can work this out. i wanna sell and u wanna buy. this may work great for the both of us
Old Mar 8, 2010 | 06:31 PM
ok well here is what is going on, im puttin a carbed 305 from a 85 Z28 into my car, i want to convert it to TPI, so i need everything, and im parting out the Z28 so idk how much i can get off the parts and idk how quickly ill get anything but i do know that my tax return comes soon, if i could get a whole setup for $300 that would be awesome, im a little leniant both ways
Old Mar 8, 2010 | 07:00 PM
1990s10's Avatar
300 is a bit low for ECM, complete workin harness etc. ecm is a couple hundred, tpi unit with injectors and all is another couple hundred. i have everything that u will need to convert this. now i dont know what heads u have but they may or not work. im not positive. if they are stock head they will most likely work just fine. this unit i have is from an 87 GTA. just so u know. but all in all for everything u will need to make ur engine run i would have to say 550-600. i have a fully functional MAF and all ducting to go with it. i could also sell u the whole engine and 700r4 trans and everything needed for 800. engine and trans has only 54k on it and is a roller cam engine
Old Mar 9, 2010 | 01:02 AM
im not looking for a motor and tranny, just the TPI stuff, i got a guy who will sell it to me for $500 and another for $320...
Old Mar 9, 2010 | 05:27 AM
904EDZ28's Avatar
Car: 85 IROC-Z
Axle/Gears: stock 3.23
Where are you located I have a setup I would trade for a carb setup. The only prob is the bottom plate for the throttle body is broke (for the coolant hose hookup), also needs a tps, and I will have to find the maf sensor but I have it.The wiring harness is not in the best shape. Let me know if interested. By the way I'm in Jax., Fl. Also some details on the carb setup.
Old Mar 9, 2010 | 10:10 AM
i would be interested in trading, im located in fox island, WA
Old Mar 10, 2010 | 05:24 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a running 87 iroc i would sell you everything for $300 plus the shipping. with all sensors, relays ect,
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
