Well as the title states i am currently switching to carb from tpi..i wanna just use the intake pump so im looking for a fuel pressure regulator could be used...just need it to be functional so i can use it thanks guys.
so nobody has a extra fuel pressure regulator laying around??
ya i do
u wanna run the in tank pump? if so i have a mallory regulator for that
gettin pics..............
yes i wanna run the intank pump...so it has to have a return thing i was told...
yep. i have the one you need. i had mine setup that way . it works good . i just pulled the tank and put the engine pump on it a week or two ago. but ya ill send ya pics in a min
cool deal and how much where u looking to get for it...shipped to 79930?
after shipping i would take 50 if you need i can send all the fittings too. ill show u what i have hold on just one min,, while i upload the photos
so it would be 50 plus shipping??
u can go in or out any of the ports around the sides 4 total
the bottom one is the return line.
the top adjusts the pressure good for 2-15 or 18 lbs
cool deal so just get back at me with a final price so we can work something out cause i need one ha ha so i can just use my intank fuel pump.
ya i think i paid 98 for it new. i have two AN fittings that go to standard size
added to those are pressure fittings for 3/8 steel line... one it a direct fit fitting . the other two have pressure fitting adapters, i do have two new rings i can send with it
ya 50 plus shipping , i dont think that it will cost that much to ship ill try to find out today
AWESOME so everything i would need just to hook it up?
it does have the mounting plate. i had it bolted to my intake and another time to my head.. once you mount it just bend it how you want it. if you need the costom fittings let me know. they are made in a way that youll have to cut the fittings on your fuel lines and attach hose to it. or i can send all the fittings except the pressure fittings if you are gonna try to plumb it all with steel
if u can pm me ur number so i can shoot u a text with my number so we can get everything going cause i need it.
ill probably just use the stock fuel lines.
the way its set up now all youll have to do is cut the fillings off youre fuel lines and run hoses to it. everything is there to make it work
awesome thanks alot...let me know on final price.
62 bucks , as is, i made a mistake on the pressure its good for 4-25lbs and works with alcohol and super or turbo charger.
if you want to look it up its at summit part #4307m
let me know when you send cash out. soon as i get it, ill ship
this is a nice regulator, very versitile. i almost want to keep it , but i will probebly never use it
aremy10 have you already sold that?
SOLD
