smog delete pulley, 91Z engine wiring harness
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
like the title says, looking for two parts;
smog delete pulley and bracket
91 z28 engine wiring harness with a/c
let me know what you've got and how much you want for it shipped to 99114 WA
thanks!
thanks!
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: smog delete pulley, 91Z engine wiring harness
I have a 91 camaro AC Harness.
lmk
Josh
lmk
Josh
Car: 1992 Camaro Z-28
Engine: 355
Transmission: Custom 700-R4
Axle/Gears: Stock 4th gen
Brisk,
I took off my smog pump and gutted it. Went down to the hardware store and bought some caps for the a.i.r. system. Been like that for years. Might save you a few bucks.
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
You do not need a smog pump delete pulley to bypass the air pump. Check out this thread: https://www.thirdgen.org/serpentine
nice post budfreak1, thanks
Engine: 355
Transmission: 4L60
Car: 91 firebird
Axle/Gears: stock
getting a longer belt is one way to do it, another way to do it with the original belt is to rought it another way
go around the crank pulley, then around the power steering pulley, then around the water pump, and around the alt. to the a/c . this is how mine is and it works good, plus you dont need to get a longer belt.
it all depends on how you want it
