AC compressor manifold assembly
Old Aug 3, 2010 | 04:02 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Does anyone have an AC compressor manifold assembly that they are not using anymore? With some pics of the part that bolts to the compressor?
Just bought a brand new compressor and it doesn't match the lines that I have on the car right now. I'm thinking someone switched out an entire assembly, compressor and lines to get it working the last time in this car. But I have no idea what the old compressor went to so I figured it would be easier to buy a new manifold line assembly since this is starting to crack anyways.
thanks
Old Aug 4, 2010 | 03:55 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: AC compressor manifold assembly
If you are referring to the AC lines that go from the condenser to the compressor and then on to the dryer for an engine with AC compressor on the passenger side, I've got a spare one that looks like new I was going to replace my older one with, but don't think now I'll use. Can send pics if you give me your email address
Old Aug 4, 2010 | 04:54 PM
mos68x's Avatar
Yeah it sounds like the same ones I'm talking about. Can you send close ups of the part that actually bolts to the back of the compressor?
leonrathburn at yahoo dot com
thanks
Old Aug 4, 2010 | 08:53 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Pics sent
Old Aug 4, 2010 | 09:09 PM
mos68x's Avatar
thanks, that's exactly what I have, I wonder why the new compressor looks nothing like my old one. and better yet, why every single older one doesn't look right either. we ordered in all the older models for the camaro v8s and they all have the same mounting area.
I might just have to order one from autozone instead then even though i really don't like that idea
Old Aug 7, 2010 | 09:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if you can pic what bracket you need i can look i probably have it or several of them
always only ever sene driver side compressor seyups on the v-8 engines
i have lots of compressor bracket sets from 80s v-8 chevies but what do you need exactly?
pm or email or text me 217 671 7792
or anyone else!
good luck
Old Aug 7, 2010 | 10:21 PM
mos68x's Avatar
I had to return the compressor since it didn't fit any of the manifolds i've found for camaros. When I can get another to attempt this again I'll post a picture up so you can see it.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
