[IL] Looking for Heads an cam!
Old Sep 3, 2010 | 02:55 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
I am looking for a set of heads and cam for my 305 TPI.
Prefferably something aftermarket, I want to pull some power out of this hog, tell me what you have! it is an 88 Roller block
Old Sep 4, 2010 | 12:14 AM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
Re: Looking for Heads an cam!
have some World Products SRT Iron heads 475.00 + ship .
TECHNICAL SPECS
Casting ID Number: I-052, I-058
Material: High density cast iron
Valve Seats: Intake (integral), exhaust (hardened)
Valve Guides: Integral cast iron
Spring Seats: Machined for 1.560" and 1.250"
Valves: Manley stainless steel valves in assemblies (inconel exhaust valves on marine applications)
Valve Diameter: 2.020" intake, 1.600" exhaust (11/32" stem)
Rocker Arm Studs: Screw-in style
Rocker Arms: 1.5 ratio (use of 1.6 ratio will require elongation of pushrod holes)
Intake Runner: 170cc, standard port location
Exhaust Ports: 65cc, standard location
Combustion Chamber: 58cc, 67cc or 76cc, straight plug orientation
Spark Plug: 14mm 5/8" .460" reach tapered style
Valve Job: Multi-angle intake and radiused exhaust
Valve Cover Rail: Raised w/ perimeter and center bolt pattern
Valve Angle: Stock 23°
Accessory Bolt Holes: Stock
50-State Emissions legal
Accepted by most oval tracks and sanctions as stock replacements. Check with rule book.
Spring Specs
1.250": 100 lbs. @ 1.810", 300 lbs. @ 1.250", coil bind @ 1.200", max lift @ .560"
1.437": 125 lbs. @ 1.810", 340 lbs. @ 1.210", coil bind @ 1.160", max lift @ .560"
Head Flow @ .500 Lift
220 intake, 151 exhaust (Super Flow 1050)
232 intake, 161 exhaust (Super Flow 600)
All heads flowed with a standard .750" intake plate, without exhaust tube, and 28" of water.
Old Sep 9, 2010 | 03:57 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
combine them with my LT1 cam work with the computer, wont need expensive springs, will make MORE power with a proper tune but if your car is a MAFS system itll compensate pretty decent and be a heck of alot better then stock 60$ shipped
i also have a set of vortec heads you can get them milled to 60 cc and have them rebuilt(i have everything but springs for the rebuild including locks retainers valves and seals, the valves are manley race flow), ill sell everything for 375 youll need a scoggin dickey lower tpi manifold
Old Sep 28, 2010 | 10:44 AM
got rid of the cam still have a set of vortec heads
Old Oct 28, 2010 | 04:12 PM
91Camaro_RS's Avatar
I have an LT1 cam as well $60 shipped
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
