Metal Cooling Hose Needed.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I need the metal cooling hose from the heater core, down to the frame rail and up to the front. Has the port on top for a hose to go to the diverter valve. GM no longer stocks it but still has the 1LE metal hose without the top port. Go Figure....
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Metal Cooling Hose Needed.
https://www.thirdgen.org/forums/cool...electrics.html
JamesC
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I think the one he means is basically the return path of the heater hoses to the radiator. Water either comes out of the heater core, down thru curved heater hose to this metal line. Or water is instead diverted thru diverter valve down to same metal line and back to radiator correct?
Car: Formula
Engine: 6.0 LSX
I need the one that is metal and runs along the frame rail and goes to the rad, or the Oil cooler lines on a TPI car with the outlet above for a hose that goes to the heater diverter valve.
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have that pipe if still needed, $20 plus shipping sound good
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
