86 IROC-Z TPI 305
Old Sep 8, 2010 | 06:12 PM
ajay51's Avatar
Want a title? Post!
86 IROC-Z TPI 305
I need a fan shroud for a 1986 TPI 305 iroc camaro
Old Sep 8, 2010 | 09:18 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 86 IROC-Z TPI 305
If you're talking about the upper fan/radiator shroud or mount from a single electric fan set up, I've got one in perfect shape. LMK if that's what you're looking for and I can send pics to an email address
Old Sep 8, 2010 | 10:24 PM
ajay51's Avatar
Want a title? Post!
How much? and does it not have the lower piece. mine looks like it is missing the lower part of the Shroud and I am having an overheating issue.
Old Sep 8, 2010 | 10:40 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
There is just this piece that holds down the radiator and mounts the top of the fan to it and the lower fan mount which I probably have too, but that's all there is to it. The fan is close to the radiator, but there's not really a normal type shroud anywhere to speak of . There's lots of things that cause overheating discussed on the cooling board, I've had to deal with most of them. You do have the electric fan, yes?
What exactly is going on?
Old Dec 27, 2013 | 08:43 PM
DD990's Avatar
Want a title? Post!
Hello, I understand the post is a couple of years old but, is it possible you still have the fan and shroud?
Jon
Old Dec 29, 2013 | 12:00 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Jon
I have the fan and both upper and lower brackets
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
