[NY] Looking for broken 700R4
Car: 87 Trans Am GTA
Looking for a broken 700R4 (4L60) trans. MUST BE 89 AND UP and for the V8 (Don't know if there's a difference). Must have a good case and valve body since I'm looking to rebuild it. Also does not need to come with Torque Converter. Would also prefer something local so I can pick up. I am willing to travel 100 miles into NJ or CT from NYC. Let me know what you got. Thanks!
Car: 89 camaro rs
Engine: 400HP 5.0L cammed to hell
Transmission: 700r4 :(
Axle/Gears: 3.23 posi
Re: Looking for broken 700R4
i have a broken 700r4 out of an 89 camaro rs with a v8.... it has the converter and the tranny is complete except for the 2-4 apply band.... the 3-4 clutch pack is fried and the reverse input drum that the band rides on could use replacement but i live in glenville, ny which is about 20 min from albany... make me a reasonable offer and its yours... and oh, the vavle body has a shift kit from b&m installed. great tranny to rebuild... call me for more details at 518-817-5013
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
its actually '87 and up are the improved with aux valve body and such
the first digit of stamping code along flat spot at pan rail is last digit of the year
'87 to 92 are the 700r4 with aux valve body
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
I have a 700R4 that I just pulled from my 88 GTA. Other than 3-4 clutch pack, the trans was working when I pulled it.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
no green
Jan 9, 2016 09:22 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
