[CA] LOOKING4 Headlight motor relay module.
Old Dec 20, 2010 | 09:19 PM
wager420's Avatar
Car: Pontiac FIREBIRD
Engine: 3.8L
sup thirdgen=). i need a headlight motor relay. its a black box that sits behind the brake fluid cylinder. the one current on my 92 fbird, 3.1L v6. mpfi works ok,but it has a short circuit and is draining my battery. having to open up the hood and disconnect the ground cable is getting annoying =P. i can leave it one for 8-10 hours at most before the battery dies out. but over night kills it.
so if any one you good honest people here at thirdgen=) happen to have one laying around. or a buddy, please give a shout =P. thanks
Old Dec 22, 2010 | 10:06 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
Re: LOOKING4 Headlight motor relay module.
I have a couple of them from 89' GTA's! I am not sure if they are the same as the 91'. They run $20.00 each plus shipping and handling. However, I must say I have never heard of these draining the battery when going bad. So, I am not sure this is your problem. Usually, your problem is caused by a Bad Regulator Diode in your Alternator or Bad Mercury Switch in your Hood Light. If you have any questions or other needs I can be reached at (805) 522-2539. I will be closed after today until after Christmas.
Thank you,
Thomas
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
