[KY] looking for a 5sp engine wiring harness.
Old Feb 24, 2011 | 03:14 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
I have a 92 T/A 305 TPI 5sp. About two years ago it started knocking. At 167000 miles I figured it was time to pull the motor and put my 383 in it and swap to carb. So I need a harness that I can hack up to make my gauges work. I'd cut my harness up but its a speed density harness and I may go back to stock later in life. SOMEBODY PLEASE HELP!!! I've never bought anything off here before so please help me out with payment.
Old Feb 24, 2011 | 07:19 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: looking for a 5sp engine wiring harness.
If you remove the wiring harness that comes from the passenger side fender, it will help quite a bit. Just unplug it from the computer and remove the fender liner and pull through. This should be for you injectors and other sensors. You can save it for later.
The harness beside the brake booster is for the gauges/starter/alternator. This should clean up the bay without having to buy another harness.
Old Feb 24, 2011 | 02:03 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
I removed the harness from the pass. side. But it runs over to the driver side and plugs in next to the booster with the headlights harness.
Old Feb 24, 2011 | 03:07 PM
Steve86TA's Avatar
Car: To many to list
I have a 5spd speed density wiring harness from a 91 Z28 TPI car..Will that help you? If so PM me and we can work something out
Old Mar 3, 2011 | 04:43 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
I'm still looking for a harness. ANYBODY???
Old Mar 4, 2011 | 10:05 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
I have a 5spd harness from an 87 z28 305 I can pull out of my car if that helps.
Old Mar 5, 2011 | 06:19 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Does it have mechanical or electric gauges?
Old Mar 5, 2011 | 10:50 PM
StringRust's Avatar
electric.
Old Mar 11, 2011 | 10:35 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Still looking!
Old Mar 16, 2011 | 04:03 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Somebody out there has to have a harness they want to get rid of?
Old Aug 24, 2011 | 06:59 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Let's go back to the top with this one. I'm still looking for one.
Old Aug 25, 2011 | 07:21 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Anybody?
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
