[VA] Looking for 305 tpi parts
Old Mar 4, 2011 | 10:54 AM
Va_Beach_B4C's Avatar
Car: 1992 B4C
Engine: 350 5.7L TPI
My brother has an 87 305 carbed and wants to convert to tpi. looking for a complete setup (Wiring harness, comp, plenum, heads, intake, tb, etc...)
Thanx,
Jeremy
Old Mar 14, 2011 | 11:10 AM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
Re: [VA] Looking for 305 tpi parts
ive got a tpi setup but its not complete if you buy it in peices itll be cheaper then someone who has it all, that would go for around 1000$ for a decent setup if not more.
check the link in my sig, ive got it all but the heads ecm and harness, you could used your heads for it those you dont have to switch out..
Old Mar 14, 2011 | 11:19 AM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I have the wiring harness, ECM, distributor, heads, lower plenum, upper plenum, runners, MAF sensor, MAF boot, distributor cover.
You will need a throttle body, sensors, ignition coil.
500 plus shipping.
Old Mar 14, 2011 | 07:32 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
i have harness and ecu all labeled.
Old Mar 18, 2011 | 05:18 PM
90_firebird's Avatar
I have a complete tpi set up for sale asking 400 + shipping
Old Mar 18, 2011 | 05:22 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
i have this check it out tpi polish sistem https://www.thirdgen.org/forums/engi...olish-lt1.html
jaridjohn
Jul 8, 2024 03:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
