Needing ta negative battery cable
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Looking for a negative battery cable for my 89 GTA. Needing one with no kinks or frayed outer insulation. Also the jumper must be in good shape. Ring terminal does not need to be there as I can crimp one on, but jumper should be long enough to bolt to radiator frame
Engine: 5.7 ltr.
Re: Needing ta negative battery cable
Needing a positive battery as well as I discovered the fused link to my alternator is bad...
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I have both
40 plus shipping for the pair.
db057
Aug 11, 2015 10:11 PM
